HI, i am giving it another try to passbolt. however, I noticed that in order to copy a TOTP i have to open the vault and search for the TOTP Record entry, VERY INCONVENIENT.
In my opinion, TOTP should with easy access to just copy the entry from the matching record when entering credentials, just like Bitwarden does.
Whats the point of having TOTP on the vault if you are going to need to open the Vault and search for it? its like having to check your phone to get authy TOTP.
Thanks
