I am using whm/cpanel. I have tried PHP 5.6, 7.0, 7.1, 7.2, with and without fpm.
Everything works fine in terms on the interface when logging in, but the command line doesnt work, and emails aren’t going out. There’s 500 errors whenever I try to upgrade OR install v2 fresh – but can’t find any logs.
Errors below are all I get thus far. I HAVE had success with emails before, so it’s not like my credentials are whack or anything. The errors below could be from emails and/or upgrading.
ERROR #1:
[28-Mar-2018 07:02:02 UTC] PHP Fatal error: Cannot use ‘object’ as class name as it is reserved in /home/pbolt/public_html/lib/Cake/Core/Object.php on line 18
ERROR #2:
[28-Mar-2018 07:04:01 UTC] PHP Fatal error: Uncaught Error: Class ‘Purifier’ not found in /home/pbolt/public_html/app/Model/UserAgent.php:82
Stack trace:
#0 /home/pbolt/public_html/app/Model/ControllerLog.php(181): UserAgent::get()
#1 /home/pbolt/public_html/app/Controller/CakeErrorController.php(78): ControllerLog::write(‘error’, Object(CakeRequest), ‘Cannot use …’, ‘CakeError’)
#2 /home/pbolt/public_html/lib/Cake/Error/ExceptionRenderer.php(292): CakeErrorController->render(‘fatalError’)
#3 /home/pbolt/public_html/lib/Cake/Error/ExceptionRenderer.php(213): ExceptionRenderer->_outputMessage(‘fatalError’)
#4 /home/pbolt/public_html/lib/Cake/Error/ExceptionRenderer.php(190): ExceptionRenderer->_cakeError(Object(FatalErrorException))
#5 /home/pbolt/public_html/lib/Cake/Error/ErrorHandler.php(127): ExceptionRenderer->render()
#6 /home/pbolt/public_html/lib/Cake/Error/ErrorHandler.php(269): ErrorHandler::handleException(Object(FatalErrorException))
#7 /home/pbolt/public_html/lib/Cake/Error/ErrorHandler.php(212): ErrorHandler::handleFatalError(64, 'Ca in /home/pbolt/public_html/app/Model/UserAgent.php on line 82
