Can not open https://passbolt.dev with chrome
Hi @all, I can use passbolt with Mozilla Firefox if I set an SSL exception for passbolt. If I use Chrome I get the same Error but also a hint that passbolt is using HSTS and I can’t set an exception for that. What can I do? I followed these instructions:
https://medium.com/passbolt/passbolt-on-debian-8-71-from-scratch-4438dad18908
You can replace passbolt.dev with passbolt.test, it should work.
After using the FQDN it works fine.
