Is it a local IP address? If it is, have you created a virtual host on your main machine?
If you are using Linux, you’ll need to edit /etc/hosts, add: 127.0.0.1 vmwpasscrp01.qsaude.com
If it’s not a local ip address, could you perform an healthcheck? su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt healthcheck" www-data
Hello @Fernandoribeiro07, I tried to resolve the DNS for the domain you are trying and it appears not registered. It has no IP associated, so when you try to access it, Chrome gives you the DNS_PROBE_FINISHED_NXDOMAIN error.
Here you can check it: DNS Propagation Checker - Global DNS Testing Tool
Do you have access to the DNS zone of the domain used to assign an IP?
You have on the hosts file a domain .local and you have used in the installation a domain .com
You should use the same for both and ensure that your nginx is correctly configured to respond to your requests on that domain.
Are you trying to access from another device different from where Passbolt is installed? If it is different, you will need to set in the hosts file of the device, the domain and the IP that have to resolve
