trying to configurate SSL access. I failed with nginx as I was unable to add CA cert.
SO I switched to APACHE with configuration below (from this forum).
Can you help me with php output ? I am not sure what that means or missing.
<?php
* The Front Controller for handling every request
* CakePHP(tm) : Rapid Development Framework (http://cakephp.org)
* Copyright (c) Cake Software Foundation, Inc. (http://cakefoundation.org)
* Licensed under The MIT License
* For full copyright and license information, please see the LICENSE.txt
* Redistributions of files must retain the above copyright notice.
* @copyright Copyright (c) Cake Software Foundation, Inc. (http://cakefoundation.org)
* @link http://cakephp.org CakePHP(tm) Project
* @since 0.2.9
* @license MIT License (http://www.opensource.org/licenses/mit-license.php)
require dirname(__DIR__) . '/config/requirements.php';
// for built-in server
if (php_sapi_name() === 'cli-server') {
$_SERVER['PHP_SELF'] = '/' . basename(__FILE__);
$url = parse_url(urldecode($_SERVER['REQUEST_URI']));
$file = __DIR__ . $url['path'];
if (strpos($url['path'], '..') === false && strpos($url['path'], '.') !== false && is_file($file)) {
return false;
require dirname(__DIR__) . '/vendor/autoload.php';
use App\Application;
use Cake\Http\Server;
// Bind your application to the server.
$server = new Server(new Application(dirname(__DIR__) . '/config'));
// Run the request/response through the application
// and emit the response.
$server->emit($server->run());
