Hi All,
Hopefully someone can help with this. Issue:
- The server doesn’t seem to like using our wildcard cert as seen below in the healthcheck output. however the browser is fine with it and says the connection is secure once it finally connects. Activity in the web ui is very slow, each of these steps take 30/45 seconds.
- The server doesn’t recognize users after the initial login and it never prompts for the password when connecting to the server, it just starts into password recovery and when I click on the password recover link in the email I get “Please wait” in the browser for a while, and then prompts for private key file/recover kit. However, it won’t accept the key. I get “This key does not match any account” or I get “Something went wrong”
- Activity in the web ui is very slow, each of these steps take 30/45 seconds and occasionally I get a 504 error. This is the error from nginx\error.log:
2023/04/18 23:14:44 [error] 38379#0: *33 upstream timed out (110: Connection timed out) while reading response header from upstream, client: IP, server: hostname, request: “GET / HTTP/2.0”, upstream: “fastcgi://unix:/run/php-fpm/www.sock”, host: “hostname”
I’m not sure what other logs, etc might be needed.
Server Version - RHEL 8.7
Webserver - nginx/1.14.1
DB Server - mysqladmin Ver 9.1 Distrib 10.3.35-MariaDB, for Linux on x86_64
PHP Version - PHP 8.1.18 (cli) (built: Apr 11 2023 16:47:45) (NTS gcc x86_64)
Passbolt - rpm -qa |grep passbolt
passbolt-server-selinux-0.4-1.el8.noarch
passbolt-ce-server-3.12.0-2.noarch
su -s /bin/bash -c “/usr/share/php/passbolt/bin/cake passbolt healthcheck” nginx
// _,///./_//__/
[PASS] PHP version 8.1.18.
[PASS] Full base url is set to https://pblt.sbctc.edu
[PASS] 30 tables found
[PASS] Using latest passbolt version (3.12.0).
SMTP Settings
