Hi, I am trying to make my local dev setup for Passbolt_api.
Point to note
- I am working on a fresh debian image with no extra configuration
- version and installs
- PHP - 8.2.7- MySQL - 15.1 10.11.6-MariaDB
- Composer version - 2.5.5
- all the dependencies are installed - passbolt_api/config/requirements.php at master · AbhishekTiwari23/passbolt_api · GitHub
- apache2 and nginx both installed
Mysql Setup
MariaDB [mysql]> show grants for ‘passboltadmin’@‘localhost’;
| Grants for passboltadmin@localhost |
| GRANT USAGE ON . TOpassboltadmin@localhostIDENTIFIED BY PASSWORD '19982AC484EEE1A991CA8D07587351B132BCCE7C’ |
| GRANT ALL PRIVILEGES ONpassboltdb. TOpassboltadmin@localhost|
My passbolt.php setup
<?PHP return [ 'App' => [
'fullBaseUrl' => 'https://127.0.0.1',
// Database configuration.
'Datasources' => [
'default' => [
'host' => 'localhost',
'driver' => 'Cake\\Database\\Driver\\Mysql',
'port' => '3306',
'username' => 'passboltadmin',
'password' => 'debian',
'database' => 'passboltdb',
// Email configuration.
'EmailTransport' => [
'default' => [
'host' => 'smtp.gmail.com',
'port' => 25,
'username' => 'abhishektiwariabhishek23@gmail.com',
'password' => 'my password',
'tls' => true,
//'timeout' => 30,
//'client' => null,
//'url' => null,
'Email' => [
'default' => [
'from' => ['abhishektiwariabhishek23@gmail.com' => 'Passbolt'],
//'charset' => 'utf-8',
//'headerCharset' => 'utf-8',
'passbolt' => [
'gpg' => [
// If putenv is set to false, gnupg will use the default path ~/.gnupg.
// For example :
// - Apache on Centos it would be in '/usr/share/httpd/.gnupg'
// - Apache on Debian it would be in '/var/www/.gnupg'
// - Nginx on Centos it would be in '/var/lib/nginx/.gnupg'
// - etc.
'keyring' => getenv("HOME") . DS . '.gnupg',
//'putenv' => false,
// Main server key.
'serverKey' => [
'fingerprint' => 'E532C2D3AC26F8C5ECA7B1670AB66F07C0159CE6',
'public' => CONFIG . 'gpg' . DS . 'serverkey.asc',
'private' => CONFIG . 'gpg' . DS . 'serverkey_private.asc',
'security' =>[
'smtpsettings' =>[
'endpointDisabled' => true,
'ssl' =>[
'force' => true,
bin/cake passbolt healthcheck output
debian@debian:~/Desktop/passbolt/passbolt_api$ bin/cake passbolt healthcheck
Passbolt commands should only be executed as the web server user.
The command should be executed with the same user as your web server. By instance:
su -s /bin/bash -c “/home/debian/Desktop/passbolt/passbolt_api/bin/cake COMMAND” HTTP_USER
where HTTP_USER match your web server user: www-data, nginx, apache, http
[PASS] PHP version 8.2.7.
[PASS] Full base url is set to https://127.0.0.1
[HELP] Check that the domain name is correct in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php
[FAIL] The application is not able to connect to the database.
[HELP] Double check the host, database name, username and password in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[HELP] Make sure the database exists and is accessible for the given database user.
[FAIL] No table found
[HELP] sudo su -s /bin/bash -c “/home/debian/Desktop/passbolt/passbolt_api/bin/cake passbolt install” debian
[HELP] sudo su -s /bin/bash -c “/home/debian/Desktop/passbolt/passbolt_api/bin/cake migrations migrate --no-lock” debian
[HELP] See. Passbolt Help | Update
[PASS] The environment variable GNUPGHOME is set to /home/debian/.gnupg.
[PASS] The directory /home/debian/.gnupg containing the keyring is writable by the webserver user.
[PASS] The public key file is defined in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php and readable.
[PASS] The private key file is defined in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php and readable.
[PASS] The server key fingerprint matches the one defined in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[PASS] The server public key defined in the /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php (or environment variables) is in the keyring.
[PASS] Using latest passbolt version (4.5.0).
[PASS] The deprecated self registration public setting was not found in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[HELP] Or set passbolt.email.validate.mx to true in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[PASS] The /home/debian/Desktop/passbolt/passbolt_api/config/jwt/ directory is not writable.
SMTP Settings
[WARN] The SMTP Settings source is: /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in /home/debian/Desktop/passbolt/passbolt_api/config/passbolt.php.
[FAIL] 5 error(s) found. Hang in there!
For SSL certificate I followed - Passbolt Help | Manual HTTPS configuration on Debian and Ubuntu with user provided certificates How To Create a Self-Signed SSL Certificate for Apache in Ubuntu 16.04 | DigitalOcean
All required ports are enabled
