HI,
I’m having some troubles with passbolt.
Everything went well during the install but when I try to reach the server from the browser with the ip:port i got a connection timed out.
I checked the passbot health check and I got :
[PASS] PHP version 5.4.16
[PASS] PCRE compiled with unicode support
[PASS] The temporary directory and its content are writable
[PASS] The public image directory and its content are writable
[PASS] The core config file is present
[PASS] The database config file is present
[PASS] The email config file is present
[PASS] Unique value set for security.cipherSeed
[PASS] Full base url is set to http://10.0.20.127:3001
[HELP] Check that the domain name is correct in app/Config/core.php
[PASS] Configured to use a supported database backend
[PASS] Not using a prefix for database tables
[PASS] 20 tables found
[PASS] PHP GPG Module is installed and loaded
[PASS] The environment variable GNUPGHOME is set to /var/cache/nginx/.gnupg
[PASS] The directory /var/cache/nginx/.gnupg containing the keyring is writable by the user the webserver is running as.
[PASS] The public key file is defined in app/config.php and readable.
[PASS] The private key file is defined in app/config.php and readable.
[PASS] The server key fingerprint matches the one defined in app/config.php.
[PASS] The server key defined in the app/Config.php is in the keyring.
[FAIL] Could not connect to passbolt repository to check versions. It is not possible check if your version is up to date.
[HELP] Check the network configuration to allow this script to check for updates
[FAIL] Passbot is not configured to force SSL use
[HELP] Set App.ssl.force to true in app/Config/app.php
[FAIL] App.fullBaseUrl is not set to HTTPS
[HELP] Check App.fullBaseUrl url scheme in app/Config/core.php
Development Tools (optional)
[PASS] Phpunit is installed
[PASS] Phpunit version is 3.7.38
6 error(s) found. Hang in there!
I didnt set the https, that’s why i got error on this part but the health check also tell me it couldnt reach the health check through the URL.
So I tried to see what i did wrong during the install but I dont see.
I followed this guide : https://medium.com/passbolt/passbolt-on-centos-7-with-nginx-php7-fpm-mariadb-from-scratch-7b2a9b15f3a4
After a quick look on the web i didnt found anything interesting.
I also double checked the guide in case i failed something but everything looks good.
If someone can help me that would be nice.
thank you and sorry for bad english.
