My setup(v2) is loosing users / PWs inserted by GUI
Dear team,
our passbolt-installation is accepting neither new passwords nor users created over the webgui.
  • The user / passwort is shown in gui for a few seconds. After a change of webpage / refresh the data is gone.
User creation over CLI is possible and working.
My setup:
VM on Ubuntu 16.04.4 LTS
mysql Ver 14.14 Distrib 5.7.21, for Linux (x86_64) using EditLine wrapper
PHP 7.0.28-0ubuntu0.16.04.1 (cli) ( NTS )
Copyright © 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright © 1998-2017 Zend Technologies
with Zend OPcache v7.0.28-0ubuntu0.16.04.1, Copyright © 1999-2017, by Zend Technologies
Passbolt v2.1 (updated from newest 1.x)
healthcheck:
www-data@test:~$ /var/www/html/passbolt/bin/cake passbolt healthcheck
/ _
//.__/__//_/
[PASS] PHP version 7.0.28-0ubuntu0.16.04.1.
[PASS] Full base url is set to https://lab.XXXXX.net/passbolt
[HELP] fopen(): Peer certificate CN=test-' did not match expected CN=lab.XXXXX.net’
#fopen(://lab.XXXXX.net/passbolt/healthcheck/status.json): failed to open stream: operation failed
[PASS] 19 tables found
[PASS] Using latest passbolt version (2.0.1).
  • the SQL-Error-Log is empty
  • email-log of passbolt is empty
  • the debug-mode is enabled in config/passbolt.php, but it does not generate any output - where is the data gathered by debug stored? email.log?
Any help is highly appreciated.
Thank you & keep up the nice work. We all like the project and are looking forward to any progress.
Can you check the charset in your database? See. Error 500 when try to recover account after upgrade to v2.0.1
We’re working on a hotfix to help with the migration.
My mysql says
InnoDB utf8mb4_unicode_ci 464 KiB 0 B
Which would be ok?
Can you check the individual fields for the table file_storage?
File_storage seems to be empty:
(sorry it is german :slight_smile: )
indizes:
Hope I got the correct info :slight_smile:
Yes so it’s the same problem, you need to change the “Koallation” following the method described in the other ticket. Error 500 when try to recover account after upgrade to v2.0.1
I just got it right. It was indeed solved by altering the fields to utf8. THanks for your fast support!
I have one other issue, also directly related to the update:
I can’t edit/copy password-entries over the gui. If I mark a PW-Entry the fields for edit, copy, share are still greyed out.
For entries that have been in the system prior to update to v2 edit / sharing, etc. is possible.
@jay1984 I think there might be some issues with the record created in the meantime, they might be corrupted. Could you try to create a new one now and see if the same error occurs? For the passwords created in the meantime you might have to delete / create them again. It’s not possible, can contact us at contact@passbolt.com could schedule a call to see if they can be recovered.
I just added a new entry. Unfortunately it is still the same issue. No edit, copy, etc. is possible when I select the new entry. The fields for edit, etc. are still not accessible
@jay1984
If you have time now, we could organize a quick call.
Send us an email to contact@passbolt.com
Can you check if the permissions table or any other have this collate issue.
We’re working on a fix right now, it would help us a lot.
