PassboltController missing
Hi @all,
everything worked fine during the installation process, but when I try to enter the frontend I get the following message:
Missing Controller
Error: PassboltController could not be found.
Error: Create the class PassboltController below in file: app/Controller/PassboltController.php
And indeed, there’s no PassboltController inside app/Controller/.
Can anyone please help me regarding this issue?
Following the report of the systems healtcheck:
[PASS] PHP version 7.0.20-2~ubuntu14.04.1+deb.sury.org+1
[PASS] PCRE compiled with unicode support
[PASS] The temporary directory and its content are writable
[PASS] The public image directory and its content are writable
[PASS] The core config file is present
[PASS] The database config file is present
[PASS] The email config file is present
[FAIL] Debug mode is on.
[HELP] Set Configure::write(‘debug’, 0); in app/Config/core.php
[PASS] Unique value set for security.cipherSeed
[PASS] Full base url is set to http://192.168.33.36/passbolt
[PASS] Configured to use a supported database backend
[PASS] Not using a prefix for database tables
[PASS] 20 tables found
[PASS] PHP GPG Module is installed and loaded
[PASS] The environment variable GNUPGHOME is set to /home/vagrant/.gnupg
[PASS] The directory /home/vagrant/.gnupg containing the keyring is writable by the user the webserver is running as.
[PASS] The public key file is defined in app/config.php and readable.
[PASS] The private key file is defined in app/config.php and readable.
[PASS] The server key fingerprint matches the one defined in app/config.php.
[PASS] The server key defined in the app/Config.php is in the keyring.
[FAIL] This installation is not up to date. Currently using 1.6.9 and it should be v2.0.0-rc1.
[HELP] See. Passbolt Help | Update
[FAIL] Passbot is not configured to force SSL use
[HELP] Set App.ssl.force to true in app/Config/app.php
[FAIL] App.fullBaseUrl is not set to HTTPS
[HELP] Check App.fullBaseUrl url scheme in app/Config/core.php
Development Tools (optional)
[PASS] Phpunit is installed
[PASS] Phpunit version is 3.7.38
4 error(s) found. Hang in there!
See. Small URL issue when installing passbolt in sub folder
